My Arlo setup seems to work well with movement across the field of vision but in the above examples it's a bit more hit and miss.
Netgear has stated the detection has improved.... time will tell how much when there are more out there.
I have no doubt with all the complaints that the detection will be at least 100% better since they did a hardware revision.
The PIR system was re-worked, there are now TWO PIRs in the Pro Cams to enhance motion detect.
How come Arlo doesn't just use a visual system like the nest outdoor cam does... and a zone setting like that same brand? It has zero distance limitations save for the pixel resolution of the sensor; basically as far as the camera can see as long as the object is renderable on a pixel.
FortyCaliber wrote:How come Arlo doesn't just use a visual system like the nest outdoor cam does... and a zone setting like that same brand? It has zero distance limitations save for the pixel resolution of the sensor; basically as far as the camera can see as long as the object is renderable on a pixel.
That would require the camera to be always on, which would quickly deplete battery.
