Arlo Pro model VMC4030 Battery is completely dead will not charge
  • 3739 Views
Ray-burn
Battery is completely dead will not charge  "changed battery" camera will not work after changing batteries.
Ray-burn,
Are you using the charging cable and power adapter that came with your Arlo Pro camera kit? What is the LED behavior on the camera?
Ray-burn
Yes I am using the orginal charger and cable, the camera will not response in any way.
The camera should run by just being plugged in - do you see any LED activity on the camera when you do so? If not, you can try a different charger from a recent phone that supports 5v and 9v like the Arlo charger.  Any luck?
You may have to use the following directions to get a dead battery charging again:
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
