Just installed Arlo Pro. Microphone volume very low. Can anyone give suggestions to fix? Volume is set to max in settings. Have tried from PC and IOS devices. Thank you.
Many users are reporting the issue has been resolved with the latest camera firmware version along with the latest app versions installed, see here: https://community.netgear.com/t5/Arlo-Pro/Arlo-Pro-weak-audio/td-p/1157949
Be sure your camera is up to date with the latest firmware version (1.090.0.0_9945 as of 11/17/2016) and be sure you have the latest available version of the Arlo mobile app from the app store.
If you are still having issues, Please contact the Arlo Support Team to further investigate. You will find several options for contacting support in the provided link.
Mic on the camera so you can hear the person or mic on your device so you can talk to them? I've found the camera mic to be very sensitive so I'd guess you mean the ability to speak so the person can hear you (speaker on the camera) which may be an issue with your devices (or not).
The volume is incredibly low on all four cameras. I can hear sound fine on the video and watching live but if I try to communicate from my device to the person near the camera the volume is low.
All 4 of mine are also very quiet when using the microphone to speak.
The speaker itself on the camera is quiet is what i mean. Volume is all the way up. Ive tried from different devices as well. Andriod, Windows.
Just tried both my Q and a Pro with the same results - the Pro is very low. Might be ok for indoors but outdoors with any background noise it gets lost.
Did you open a case with support? The only way to actually escalate the issue is with a case - when lots of people say the same thing, it gets attention.
Ok, I just tested mine with my son and he said he can hear me fine and clear while at the door. He stepped back approximately 12' where my gate is at and he was still able to hear me clearly.
I am currently using an Android S7 Active.
What firmware?
Android 6.0.1
Tanbuck wrote:
Base is 1.8.2_9322 and cameras are on 1.088.0.0.0_9373
Mine are the same.
Mkjne, too. Dunno what that may mean.
Thank you all for the feedback, I have escalated this topic for further investigation. I will post back when I have more information.
@RobertRosal Where did you buy yours? Do you have the 4 camera bundle?
I just opened a case with Netgear, but the call was taken by their call center. No way to speak with real tech support people. It does not appear that they have that type of arrangement where a customer can speak with someone technical.
Anyway, I'm planning to return mine to the store during this week. Still having issues with all four cameras, unable to hear through the speaker without standing directly beside/under them.
Not entirely sure if there is a batch defective or what. However, I'm not a happy camper now.
We are aware of an issue with audio on the Arlo Pro and are currently working hard toward implementing a fix as soon as possible. I will keep you updated with any new information I receive on this topic.
Try calling 408-638-3750 and select #2 option to speak to support . I was able to talk to someone . they are aware of the problem . They took my phone # and e mail address
All four of my cameras are having the low volume issue and yes they are turned up to 100%. It's pretty bad Arlo would launch this product when the feature doesn't hardly work . If the issue isn't resolved soon I'm going to return the cameras.
Same issue here. Speaker on cameras very low. No one can hear me. Very dissapointed! My wife is dissapointed too and asking for me to reutrn them since this feature was one she was very interested on. I will wait a week or so to see if this issue gets fixed by then.
