- 2
Just installed Arlo Pro. Microphone volume very low. Can anyone give suggestions to fix? Volume is set to max in settings. Have tried from PC and IOS devices. Thank you.
It works fine with a browser so it's just an app issue.
Speaker volume extremely low on the camera itself. Quite a disapointment indeed. This was a major decision on the purchase.
Base firmware 1.8.2_9322
camera firmware1.089.0.0_9605
Update: Engineering has identified the root cause of this issue. We are currently testing the fix internally and hope to have a release very soon that should resolve the issue.
Thank you for your patience during this process.
Thank You James for the update . I know you guys have to be as happy as all of us on this great news . Thank You Netgear for the help and support. I aiways felt that good companies will alwys be good to there products . THANKS AGAIN Norm547
Brand new. Sound is very faint. Ver.2.2.1_14802. Not only that but it won't stay connected to my new r8500 router which I purchased thinking Arlo support was native. Signal is 100%.
Like I have been saying all a long ,call support and I found them very helpful . Trying take care of this youeself will only cause you to get upset and mad . Give ir a try ,CALL THEM
James any update as to how long?
I am on
base firmware 1.8.2.1_9773
base hardware vmb4000r3
camera firmware 1.089.0.1_9815
camera hardware: H7
iOS app version 2.2.0
No change in tested dB wiht my meter. Support says latest firmware was not about the volume issue and they are still working on it. Is that correct?
Thanks!
Psaras,
Many users have reported that after installing the latest app versions they are no longer experiencing an issue. Are you still having an issue after having updated the app?
The volume is definitely louder with the new update.
Shadowboricua wrote:The volume is definitely louder with the new update.
Too late. Went with Nest.
I have the most recent update and it has not fixed the volume on the microphone .
Just had new firmware last night and had a chance to test it today - last test was a couple of weeks ago. I'd say the volume for outdoors is marginally better but not loud.
I'm seeing a problem in Chrome on W10 where the volume slider isn't displaying properly. Firefox is fine as is the Android app. Check your volume setting to be sure that it's not set low.
Many users are reporting the issue has been resolved with the latest camera firmware version along with the latest app versions installed, see here: https://community.netgear.com/t5/Arlo-Pro/Arlo-Pro-weak-audio/td-p/1157949
Be sure your camera is up to date with the latest firmware version (1.090.0.0_9945 as of 11/17/2016) and be sure you have the latest available version of the Arlo mobile app from the app store.
If you are still having issues, Please contact the Arlo Support Team to further investigate. You will find several options for contacting support in the provided link.
Just purchesed mine yesterday have the latest firmware and can not here unless camera is within 2 feet of you and very low. I checked the volume in the app shows 100%. It needs to get louder other wise 2 way talk does not work and that is the reson I purshed this itm.
time,
This could be due to the output volume of the device you are using. Are you using a PC or a mobile app (if mobile app, which one and what device)? Do you see the same behavior on both?
I am using a i Phone and IPad with the latest app on them. I found it is a little better when I hold the phone mic next to my mouth and talk load. Have not tried a PC only have macs here and have not tried that.
I have 4 regular arlo cameras......just added this arlo pro......same issue as everyone else...low volume....updated to latest firmware when I hooked it up....tried it on both the iPad Pro, iPhone 7 and also a Samsung s8plus......all apps up to date......now someone tell me what the problem is?? I'm about ready to send all 5 and base station back.......I've tried online chat....waited 20 minutes...nobody showed up......tried calling the support number where after waiting on hold for 30 minutes I have up.........not sure what I'm dealing with here, but I sure am frustrated
App or browser? Have you tried both? For the app, try reinstalling and be sure to accept all permission requests.
Was on the app because when I tried the browser it just went to the page that told me to download the app. It's just crazy that on my my wife's phone and iPad, and my phone and iPad that all the apps would be wrong? I'll give it a shot though. Thanks
wacoachrusso, BKGiff, Jwize4206
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
- 2
