Can ArloPro be used in Australia at 240 V? Model not released here and I am impatient.
Mikamble,
You can use Arlo Pro anywhere in the world. If you purchase an Arlo Pro system in the US and plan to use it elsewhere, keep in mind you may need a special power adapter.
Arlo Pro will launch soon in regions outside the US. Closer to the end of this year or early next year.
Mikamble,
I've just done exactly that. The router will need a 240-110V transformer for it's power adapter that is 110V only. The USB charger which plugs into the cameras is worldwide voltage so you'll only need a physical adapter.
240-110V transformers seem easy to source in the US since travellers originating from there will often need it. I bought mine from ACE Hardware.
http://www.acehardware.com/product/index.jsp?productId=1390288
Enjoy!
Hey Harlo,
Just wanted to know if you've had any issues using the system here in Australia and if anything else is required besides the adaptor for the base station.
Is there any update on Arlo Pro sales in Australia yet?
Also will there be additional accessories such as solar charging panels?
April 12th will be the official Arlo Pro availability date (through JB HiFi and Harvey Norman).
I do not currently have a release date for the Solar Panel, see here for more information: How can I use the Arlo Solar Panel?
