Arlo Pro has lower signal at the exact same spot as the Arlo
I went ahead and bought an add on Arlo Pro. I went ahead and took off the older Arlo Camera, and put the Pro at the exact same spot, but now wifi signal is at 2 bars instead of 3. I'm using the existing Base station, it hasn't moved or been touched.
When I take the Arlo camera to my front door, I get 2 bars, when I take the Pro to the same spot, I get 0-1 bars.
Is it a bad camera, or does the Arlo Pro have an expected worse signal strength. I'm using the existing base, so hopefully that doesn't cause an issue. If I need to buy a new base station, that's fine, I just want to make sure I get the best signal all around.
The Pro def detects motion quicker and I love the Mic, but the videos are a bit grainy, worse than the Arlo, so I'm guessing it's due to the worse signal level.
greekspiro,
Does the Pro camera get a good signal if moved closer to the base station?
The grainy image is very likely due to the connection as you suspect. This may take more in-depth troubleshooting to further isolate, I encourage you to contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
