Good afternoon,
So I just got the Arlo pro cameras and so far they seem pretty good except for some brightness issues.
Seems there is basically 5 brightness settings.. The brightness dot all the way to left I will call 1 and all the way to right 5.
I have 3 cameras and all do the same. At night I would have the setting set to 4 and I could see good enough, 5 to bright and 3 not enough.
During the day you can still see but it is to bright in most area with it being on 4 and 3 is alot better.
Is there anyway to get the setting where it is both good for day and night. I don't want to worry about remembering to constantly change.
Below are some pictures with the how the cameras are set.
Thanks for any help or suggestions.
I find 3 is the best. I think the problem for you is the position of the camera in relation to the wall. The right 1/3 of the image is lit up bright white and thus the rest of it is relatively dark. I'm sure moving your camera will give you a much better result at 3
Small upgrades like this would make the product much better.
I was looking for the same type of time based brightness setting like you.
1st night of usage... Fast forward to morning and the images were blown out naturally.
