Hi @Rustedryder
What version of the Arlo app are you using?
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
Hello Shayne,
I am using version 2.13(2334).
I’ve been trouble shooting this on and off since mid January performing the following steps but not necessarily in the order listed.
Changed out the Cat5E cable from base station to router
Changed Ethernet port on high speed router
Assigned a static ip to VMB4000 within router
Attempted to turn camera(s) off from within settings then back on; also turned camera off from within settings then logged out of Arlo and back in turned camera on with no effective resolve
Changed the name of affected camera(s)
Deleted and re-added camera(s)
Turned off 2 of the 5 Pro cameras; issue remained on the 3 remaining cameras
Increased high speed service from 60mbps download X 10mbps upload to 160X15
Removed USB external drive from VMB4000 to free up processing time and memory
Performed restart of base station from within Arlo (sometimes resolving the issue allowing me to connect to affected cam(s) but not always)
Assigned QOS on high speed router to Ethernet port
i think that’s pretty much everything I’ve tried but the issue remains constant, if a camera senses motion and starts recording, all is good for that particular instance, however if something else happens that causes the motion sensor to trigger within a moment or two of the previous recording then the camera fails to connect and record but I do get the notification of motion detected. If I try to manually connect from my IPhone, IPad or laptop I get a failure to connect to camera.
I would definitely appreciate any assistance you could offer on this most troubling issue. I count on these cameras as an early warning device and as I indicated in my initial post, they were flawless until early to mid January of this year.
Sincerely,
Mark
HI @Rustedryder
Thank you for the detailed information. Have you tried other phones/web/devices and tested this issue?
Yes I have, I have an IPhone 6S and an IPhone 7 both running IOS 13.3.1 an IPad IOS 12.4.5 as well as a Dell laptop Win 10 using both Google Chrome and Microsoft Edge with the same condition across all devices. I also disabled wifi on my mobile devices with the same issue on 3G and LTE. The only difference is on my laptop I get a failure msg within the affected cam viewing pane “The request timed out” compared to on my mobile devices there is a “connecting” msg and a spinning spiral along with the speaker and motion icons go from white to grey as though it is going to connect then back to white immediately at which point I know it will not connect.
Just to double check, this is occurring on multiple cameras correct?
I have checked your account & it looks like all your devices are up to date on there latest firmware as well.
I see that you have tried just about all troubleshooting steps. Have you thought of performing a factory reset on your base station & re-adding the base/cams?
Yes I have, more than once and even changed base stations along with the addition of a new Pro cam. It always reverts back to the conditions identified within my original and subsequent posts.
Opened a case with Vin 2020-03-26 at Arlo support. will provide updates as they become available.
Thanks for listening to your community and all of us devoted to your products. You have restored my trust in your products!!!
Having similar problems with my Arlo Ultra SmartHub and cameras. Just started not allowing me to connect to live view of the cameras, is now only taking still images instead of video, and will not allow the Doorbell and Chime to be connected to the base station or synced. Multiple chat attempts with the Arlo support team have been disconnected. The firmware says it is up to date. Have tried the troubleshooting steps that other users here have tried as well. Any help is appreciated...
Issue corrected by uninstalling all devices (including the base) and setting up system as new.
