Hey all,
I have a 4 camera set up. 3 are non pro models. My front door is the Arlo Pro. About a year old, maybe less. Never had a problem with any of them. Now all my cameras except my front door (pro model) works fine. Front door does not detect motion. I checked all settings, everything is good. When I turn it on, it works fine. It will not pick up motion which as I said is on. Sensitivity is good.
When I put it on to check motion, notihing. No light on it, nothing. Just wondering what to maybe try.
Thanks.
Brian
Sounds to me like you should contact Arlo support next. https://www.arlo.com/en-us/support/contact.aspx
