Try and swap the camera with one of the others to see if problem continues... ( camera or location )
But, you may just find that the light reflecting off the Flag is the problem.... you need the "general" direction but you may be able to angle it a bit to eliminate many false trigger
Remember that the detection for people is less than 25 ft, so try not to cover more area than it can detect same.
I re-aimed the camera avoiding the area where the flag waves. Swapping cameras is difficult as it is semi-permanently installed necessary to extend over a gutter. This should help!! The issue now is that I need to purchase a fourth camera to cover the area by the front door. Any suggestion on how to minimize this expense!
Thanks for following up, by the way!
