The camera seems to have several issues. It constantly goes offline. It’s my closest camera to the base station. I’ve tried resynching but that doesn’t help. Now the battery shows 5% strength. I replaced the batter and it remains at 5%. Now I tried powering directly with mains line and still shows 5% battery.
Have you swapped batteries around between cameras? You can use the Contact Support link at the bottom here for hardware problems that can't be solved here.
Yes, I have. Same result. Shows 85% on original camera but when moved to problem camera it shows 5% and won’t update at all.
Use the link mentioned above for a hardware problem.
