Arlo Pro camera disconnecting
  • 1 Reply
  • 3054 Views
Numicice
I have been using the arlo pro 4 camera system now for about 4 weeks and I seen to have 1 finicky camera that consistently disconnects itself after about three days of otherwise normal operation. I have to pull the battery and go through the connection procedures to get it to work again. It will work fine for a few days and then shows up as not connected. Anyone have any solutions for this problem. I have a full battery and WiFi signal so this doesn't make much sense. Any help is greatly appreciated.
The solution is to swap the camera with one of the other ones to see if the problem follows the camera.
If it does, then Contact Netgear Support and you'll have the basis for warranty replacement
