Arlo Pro battery charge indicator
I have brand new Arlo Pro cameras. I've been testing them for a week now, yet all of the batteries are still indicating 100% charged. I tried removing the battery from one and restarting it, still shows 100% charged.
Any ideas as to why the battery charge level is not changing?
I guess the voltage is still at or above the threshold for reading 100%
Isn't it better that it stays higher longer?
Check it in another month or leave the live view on as often as you can for as long as you can to try and drain the battery if you want to
The battery icon is divide into 4 parts...
( not exactly sure but fiq each is 25% )
If the battey is 80% then it may still show FULL
Funny tho , I find the battery icon most accurate on IOS... PC and Android read about same.... just the algorithm tho in sw
