Arlo Pro base station disarming itself
Problems with base station. We have had several base stations - all of them will at some point set themselves to disarm. A few days ago we got an arlo warranty replacement base stations for issues the previous one had with USB ports not working at all. The refurbished replacement came and it was in a schedule with 2 modes. However it changed itself to disarmed at midnight. Any ideas on what causes this? We have 3 profiles. This issue seems to happen at some point with every Arlo Pro base station we have had.
Not sure/ forgot is this just a Problem in the custom schedule ? We are now trying to just use the armed mode only / no schedule.
Are you setting the schedule from an app ? Have you tried it via the web ( which I find more stable )?
Have you tried contacting customer support regarding this issue with the refurbished device? I have attached the link here for you - Arlo Tech Support
@Retired_Member
