Is there a way to disable the requirement for password to open app on my phone??
I use fingerprint, but it often doesn't work and then makes me type in password. At 4 a.m. I'm trying to see why my camera is going off and I can't even get the app open!
7 REPLIES 7
What phone and OS?
On both my S7 and Ipad, I never enter the password, it auto populates on both with the remember me checked.
On the S7, when the phone is locked with finger print but no issue there either
But also, on both I never sign out, just swipe away or send to background.
I have Samsung S6
I never log out either.
But it makes me sign in.
I do NOT get any choice for remembering password.
It remembers my e-mail address.
That's been happening to me some lately, too. If I force close it works fine as sometimes using another app and trying again. It's just the recent 2 apps that have done this and not all the time.
Larc4,
Do you get the same behavior if you disable fingerprint login? Unless you specifically tell the app to log out, or force close, it should automatically sing back in.
On my Samsung Galaxy S7 I never have to enter the password it auto-populates. Even when I force close which I have to do offen because the app hangs between modes arm, disarm. Then I have to force close and reopen but I don't have to enter my password. I hope they fix the app so it stops crashing all the time
James...I don't know. I've always had the fingerprint on. I'll try it without and see
With the iPhone 6 fingerprint on I also had this problem. Turning the fingerprint off and staying logged in, the app turns on automatically without having to put in your password.
