Just brought the Arlo Pro system home and I was told that i could connect using a mobile hotspot
but I dont know how to do it. I am using an Android smartphone that has the hotspot turned on all the time.
I have a netgear router and a Verizon router but I dont know how to connect the base to the router and the router to the hotspot
The Arlo base needs to be plugged into either a router/modem/switch via the ethernet cable.
Not sure why if you have two existing routers you would want to use a hot spot.
I am not even sure you can connect a router wirelessly to a hot spot.
Maybe I am missing something.
One of the easiest way to hook a base unit into a hotspot is if the hot spot includes an ethenet port like some do... If not , then use a wif extender with an ethernet port ( very common )
