A few weeks ago I bought my Arlo Pro Wire Free Cameras. The base is connected directly to the modem as required. Every two/three days, the base appear to be offline with the middle light orange. Hence, I cannot access the cameras - they appear as offline. No other device experiences the same lack of connectivy.
What coudl be the problem?
-G
I have exactly this problems.
I have found that rebooting your router once a day helps with connectivity. I have installed a Woods Digital Lamp timer to turn off at 0300hr and turn on at 0301hrs for the router and another timer on the arlo base station to turn off at 0302 and on at 0303. Basically, both the router and the base station reboot between 0300 and 0305. This clears the internal memory and helps to keep both devices functioning without lag or connectivity problems.
