  • 1287 Views
333Luz
Internal use of arlo pro vms4230s plugged in . Want to view live stream and speak at the same time-does this camera do this? 2 cameras connected.
You can live view and speak thru the camera tho it is not full duplex like a phone ( where both can talk at the same time )
Lag depends on your data speeds a bit, I see a 1 sec delay
333Luz
So I did setup and sync for 1 camera on same network as camera. Now I am away, so not on same network and account shows no camera to view. Do these cameras not have remote access? It doesn't make sense.
You can access remotely  - you don't need to be on your home network.
Are you using the app or the web interface?  If the app, are you using it on iOS or Android?
