Can the Arlo Pro Wireless HD cameras display be set up on a tv monitor while displaying 6 live feeds all viewable in 6 sections on 1 tv monitor continuous?
Like the type of tv displays they have as you walk into a bank or liquor store sectioning off different areas warning you that cameras are watching.
And if so, where can i find the instructions on how to set it up.
Thank you,
much appriciated for your help!
No this can't be done.
I wish.....
It will play the library files on the big screen via xbox one browser...but the live playing does not work due to lack of flash.
Someday Arlo will support html5 .
Depending on the equipment available, you could cast your mobile device's app to the TV. Of course, the display will be exactly what the mobile device shows which likely won't be more than 4 cameras if using a tablet in landscape mode.
The closest thing might be Arlo for Apple TV app. It *might* be able to start and keep live view for multiple cameras in a grid UI. Sorry can't remember exactly but if you have an Apple TV (4th gen) it doesn't hurt to try, as it's free anyway.
