The Sync button does not work, lost connection and was never able to reconnect. After many attempts, community questions and trobleshooting it still doesn't work. I also removed it fro the base station and tried to reconnect and nothing. I replaced the battery still nothing. I even tried to sync it without the battery just plugged and nothing. The Blue light works because it flashing rapidly when I insert the battery and/or connect the charging cable. I reconnected my other camera just for testing and it works. The camera was not dropped or dammaged in any way.
Are you briefly pressing the base sync button first? When pressing the camera sync button, does it flash blue and amber? If not, what happens when you reinstert the battery - it should briefly flash blue when the battery makes contact?
I get a quick flash blue light when connected to battery or just power supply with no other lights afterwards.
When connecting an additional source of power, the blue light flashes rapidly for a few seconds. This is followed by no other light status.
After letting this set all night charging a battery It now is flashing blue and amber for about a minute or two with about the same amount of time with no light to flashing blue and amber again.
You may have a bad camera. Open a case with support:
