  • 1 Reply
  • 3105 Views
GearNetRouter
Virtuoso
Virtuoso
Hi if I am gonna be swapping out my system for a different one and want to keep my existing account, is that possible? Want to move to different location. And move other one here to test something.
Just remove from account and add new one? Will my library stay or I need to download all the photos?
What about resetting it and reinstalling? Same question, can I retain the photos and the username and PW? Or I have to download all the photos?
Thanks in advance!
It's not hard and your account stays the same... all data saved
If you can add the new base first ( tho it shouldn't make a diff ) by using add device...
Then delete the cameras one at a time and sync them to the new base.
When all done , use remove device on the #1 base.
