  • 2 Replies
  • 1917 Views
rg71656
My Arlo pro cameras although they are enabled and synced with my alexa show, will not work I uninstalled and started over still will not work. They use to work. My son having same problem. When i review problem it says its solved but its not arlo, you need to fix this problem not give us run around.
ShayneS
What firmware version is your/son base station & camera running? Did the Alexa Device receive a new update that you know of?
rg71656
Not sure about updates but his and mine nither one will work with alexa. It says device or group camera 1 2 3 4 not responding. Like i said tried to reinstall with no success. Where do i get update?
