Does anyone have the issue of when looking at a motion recording the sound only starts after 1-2 seconds into the recording instead of starting at 00:00? Is this normal behavior?
I have escalated this topic and engineering has informed me that this is expected behavior.
Noticed the same here over the past couple of days. Nothing changed, so something they are doing.
It used to pop up with sound almost immediately, now there is a 1 or 2 second lag before you start hearing sound with the video.
Will this issue be fixed in future updates?
Bbiggs23,
This behavior is intended by design. See solution above.
