Any reason the Arlo Pro will not pick up motion. Sometimes it will not pick up me going out the door, but will pick up me coming back in later. At times it will will not notify or record but will start back sending notifications and recording on its own later.
Ensure your motion sensitivity setting is correct in the rule for this camera in whatever recording mode you're using. I recommend you turn it up to 100 and turn it down 1 each time you get a false alert within, say, 30 minutes of a previous false alert. You'll probably find the sweet spot in the 90s or even 100 where you record everything you want and minimise recording things like trees swaying or trucks going by.
For the delayed notifications and library recordings, power cycle your base station
Make sure you're changing the sensitivity in the right place. That's in the RULE within the recording MODE you're using. Then when you alter the sensitivity, go back a screen and click SAVE. Really important to save the change
