Previous posts indicated that the Arlo Pro was going to get a solar charger accessory in early 2017. Do you have a more current release date for the solar add on and when it will be available at retailers such as Amazon? Thx
Arlo,
I'm not getting anything via search engine but I wanted to post to note the following:
"The Arlo Solar Panel makes using your Arlo Pro or Arlo Go Wire-Free cameras simpler than ever. Targeted market availability for the solar panel is early 2017."
So, it's "targeted marked availability." That probably means it won't be available on a large scale for quite a bit. At least, if I were you, wouldn't expect it.
Sorry,
Dave
Arlo,
Sorry,
Dave
arlopro1031,
Currently, I do not have a more specific time frame for release. As mentioned above, the targeted release is still early 2017.
I saw Netgear showing off the solar panel on a new facebook post. It has to be close to release! It's bigger than I imagined.
Hello,
Any update on the tiiming? We have our cameras at a vacation home, which we are visiting in March. Hoping to get solar panels before then.
Thanks!
Mike
