Arlo Pro Solar Panel - Need Extension Cord
  • 2 Replies
  • 4372 Views
piperjoe68
I have purchased an Arlo Pro camera system, and just got the solar panel.  However, from where I have my camera mounted, the 6 foot cable that comes with the solar panel is not adequate length.  Are there extension cables?  Thoughts?
doczenith1
USB A extension cables are available.  Make sure to get a USB 3 cable as I had an older USB 2 extension cable and it limited the amperage when using it for charging a device.  The better and possibly cheaper alternative might be purchasing a longer micro USB cord to use instead of the included 6 foot cord.
As long as you can seal it adequately. Note that warranty claims may be disallowed due to the use of a non-qualified cable.
