I have purchased an Arlo Pro camera system, and just got the solar panel. However, from where I have my camera mounted, the 6 foot cable that comes with the solar panel is not adequate length. Are there extension cables? Thoughts?
USB A extension cables are available. Make sure to get a USB 3 cable as I had an older USB 2 extension cable and it limited the amperage when using it for charging a device. The better and possibly cheaper alternative might be purchasing a longer micro USB cord to use instead of the included 6 foot cord.
As long as you can seal it adequately. Note that warranty claims may be disallowed due to the use of a non-qualified cable.
