  • 9 Replies
  • 7669 Views
  • 6 In Conversation
Ilflyer12
Recently the scheduling capability stopped working with my cameras and the iOS app. I am not able to schedule the camera to be armed from 12:00 am to 8:00 am when another setting change occurs. When attempting to save it, it disappears from the schedule. I was able to save it on the website but modifications make it disappear and even though it shows, my cameras show a disarmed status during this window in the schedule. Please help me fix this issue so that I can go back to leveraging a schedule. Thanks
A new version of the iOS mobile app is now available from the app market: Release Notes - iOS App 2.5.5 -12th August 2018
Please make sure you have the latest version installed.
9 REPLIES 9
Uninstall and re install the app...( actually fine it much easier to do o the web ( https://arlo.netgear.com/ ))
Confirm that the time scheduled do no overlap each other.
(You can not go thru midnight, most common mistake )
Ilflyer12
Thanks for the suggestion but even with reinstalling the app, the morning schedule disappears after saving it. Any other options?
gilbo2
Luminary
Luminary
I am experiencing just the same issue. My work around at the moment is to use the "Armed" mode during the period 12:00AM to xx:xx
Be interesting to hear if you see the same?
Ilflyer12
I am seeing the same issue except when I attempt to use Armed, it still doesn't work. I have to manually change the state or else I get no notifications / recordings.
gilbo2
Luminary
Luminary
Strange and annoying!
My only other suggestion is to setup using a web browser rather than the app for now and see if you get setup and running again that way.
Milwauken
I am having problems scheduling when the four Arlo Pro cameras will be armed. The start time defaults to 12:00 am when I try to set the end time. So if I want to arm the cameras from 11 pm to 5 am, I start by setting the start time to 11 pm. But then when I set the end time, the start time goes to 12:00 am. Setting the end time first doesn't help.
You can't span days like that. Use 11PM to 11:59PM and again from 12AM to 5AM. Set the end time first for the late night part.
Milwauken
Thanks!
