All 4 cameras, multiple wires, multiple chargers, multiple outlets. Have used for 2 years with zero issues. Then all of a sudden, all 4 cameras are failing to charge.
2.1A, 5.2A. I do not have a 9A charger, but that would likely be the same result.
Tried all the tricks I read here (no batter, reset, sync with no battery, etc., all receive the same error).
This is ridiculous, Netgear. If you're reading this. These devices are WAY TO EXPENSIVE to allow this problem to arise undetected in any testing.
Any official guidance from Netgear on how to fix these paperweights?
Official support is gained by using the Contact Support link at the bottom here. This is a user forum.
Not sure why you're trying different amperage chargers. WHat's needed is a Qualcomm QuickCharge compatible charger that supplies both 5v (at ~2A) and 9v (at ~1.3A) voltages such as supplied with many recent phones.
Different chargers have different amperages, and I was simply trying everything I've tried in the past, successfully. I was simply stating that I tried the 5v 2.1A and 5v 5.2 A chargers. I have not use the Qualcomm charger you are referring to, ever.
Are you stating that a 9V charger is required?
Yes...
the pro and Pro2 requires a dual voltage usb charger... 5&9v.
you can’t charge a 7.2v battery with a regular 5v USB adapter
where is the original supplied charger?
