  • 4 Replies
  • 5822 Views
  • 5 In Conversation
Thomas1010
Help! My red panic button has disappeared off my app! I have used it around 6 times, but now on the bottom of the home screen, it has been replaced with a green “add device” icon. I took some advice and rebooted the whole system and had to take my cameras down to sync back with the base unit (PAIN), No success.. The only advice has been to go into “Modes” and adjust volume for specific camera. But that too does not get my Red Panic Button back on the bottom of the home screen. Somebody with some good buttonology skills please send me a clear answer. Thank You!!
migman_2001
Luminary
Luminary
migman_2001
Luminary
Luminary
dp0609
I noticed on the Arlo app, there used to be a button to activate the siren. Where did it go? it's no longer there, how do i activate it now? I have the free subscription plan. Thanks
arpr1
There is a gray line at the top of the app when you log in (on the camera view) that you swipe down and it allows you to activate the alarm/siren.
iOS apparently has a gray line. Android has a tab at the top for a pull-down drawer. Web uses a blue bell at the top.
