Arlo Pro Nightvision question
  • 4 Replies
  • 3938 Views
Vegas771
I've had the Arlo system for about a year.  It has it's issues, but generally works well and is convenient.
I have a spot to monitor that isn't easy to get to for battery changing, so I ordered an Arlo Pro.  Everything seemed to go well.
During the day, picture is fine, detects motion better, etc.
However, when night came, all I got was a black screen with some background lights (however, snapshot mode worked fine).  The brightness slider did nothing.  I read that re-syncing it might fix it, so I did that, but no change.  I read that disabling pan and zoom might fix it, but I couldn't find where to do that.
I was going to box it up and sent it back to Amazon, but I checked this morning and sometime in the night, it started working properly.  I still have some time to return, so I was going to leave it up for now and see what happens.
Questions:
(1) This seems to be somewhat common.  Do I have a bad camera?  And will it keep dropping out like this?
(2) How does one disable pan & zoom?
(3) Any alternatives to Arlo?  I can run power to the camera, but I need wireless transmission of the picture.  Arlo seems to be in able to handle the range fine, but it is a ways from my router.
Thanks for any help and/or suggestions!
1) It has happened before, but I won;t say common
2) just re click on the picture and it should go back to regular/full view
3) search the web, there are many ...all with +/-'s
Vegas771
Thanks.  When you say 'happened before' do you mean it happens from time to time, or just happened once and it's fixed?  Re clicking the picture when zoomed doesn't do anything, I find I have to click reset and that seems to make it full.  I get a connection error from time to time when I try to live view.  Seems to record ok even around the same time.  Just kinda weird.
1) It has happened before, but I won't say common
One or two other users have mentioned similar over time before
Vegas771
Thanks again.  I guess I was wondering if it was a sign of a defective and/or failing camera.
