  • 1 Reply
  • 1170 Views
kwhitley762002
So for one of my Arlo Pro's,  whenever I take the camera down for recharging, I always have problems getting the camera put back in the same exact location so that it detects the motion I need it to.  Is there any way to actually determine where the motion sensor is actually looking. I understand it is a 110-degree angle. I have tried the motion test and it seems to be only detecting me from a few feet away.   Also, it seems after this last recharging that the range of motion detection has been severely limited.
ShayneS
You will need to manually see where the camera is being placed through the app or the web portal. Have you tried to reboot the base station and test again? You can try and re-sync the camera to the base station as well.
