  • 5 Replies
  • 4024 Views
kwa_arlo
Does the Arlo Pro Mic & Speaker work with the original base station?
5 REPLIES 5
Yes.
JPiper
The solution is not available on the site.  When you click on the link, it does not take you to the solution.  May arlo pro cameras speakers are not working.
The solution is my reply.
The Pro speakers are very low when using the app. Verify by using the app and a browser. Also, check your settings to ensure the speaker isn't turned down.
JPiper
Speaker works fine for two of my cameras in app and browser.  All cameras have the updated firmware.  All have the volume turned up to maximum volume.  The other three cameras do not work to capture sounds through the speaker and the mike does not work.
JPiper,
If 2 of 5 cameras are working, this could indicate an issue with the cameras. Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
