For 2 arlo camera system, can I remotely turn off one camera but leave on the other one?
Yeah, you can turn the camera off remotely.
Yes as mentioned... look into createing custom modes..... do search re create mode
What this will do is separate the two cameras ( from the default of ARMED or all on ) so you can use a mode named like INSIDE or OUTSIDE
Yep as TomMac mentioned....I have camera's setup as outside and inside modes, and then use scheduales to merge them together etc.
