  • 5 Replies
  • 3554 Views
WallaceTech
Hello.
I am from the UK and i am looking at purchasing a single Arlo Pro + base station. I might look at the Pro 2 at some stage. However , I like the Arlo because i can choose to have it wireless or have it powered.
As i plan to power the camera, Will i be able to connect in a watch real time? Is there a time limit to how long i can view?
Also is there anyway of getting some kind of continuous recording or is eveything event based?. I might have some more questions as i go. Thanks in advance
5 REPLIES 5
Yes, there is Live View, but the Arlos do shut down at about 30 mins...this is in case you left it on so not to kill battereis ( even if on ac )
You can have 24/7 recording with the CVR option on the Pro2 model if plugged into ac but not on the Pro.
It still records on the event triggerings in the library but also in the CVR
BTW, the Pro2 is sort of a Q camera while on ac power, but a regular Pro model when on batteries
WallaceTech
Ok thanks mate. I think i have found a Pro 2 camera and just need to buy the base. I have posted in the Pro 2 section to confirm that the Pro 2 will work with a Arlo Pro base station.
This is a big investiment even for a single camera setup. £362 so want to make sure i get this right.
Are you mounting inside or out...what is your usage ?
WallaceTech
So it will be monted outside on my house looking down on my drive way. Will be high up so to stop it being removed. I plan to power it. We have a small window we never open and have seen you can get thin cables that will pass through windows. So will be powered all the time.
I want to be able to connect in any time and see the live video feed. I want recording not just event based. Although do want to be notified. It seems the Pro 2 is what i need to be looking at.Expensive stuff compared to the Pro 1
Is it possible that the Q camera may be better suited ??/ the Q will detect motion thru glass, while the Pro wil not
And the Q is a better rez picture
the Q with the cvr has 24/7 recording But does not use a base,,, hooks directly into you wifi
check the specs at page top
