Re: Arlo Pro Live Feed Lag
LittleMagic
I consistently get at least a 10–20sec lag when trying to live stream from the Arlo app to my cameras. No difference if, I’m only a few feet or right up close to the camera. I have a google home hub and several amazon fire sticks., tablets, and a few other devices on my network.
Model: VMB3000 | Arlo Base Station
Justin007
@ShayneS ,
Any magic solutions to suggest to the multiple users reporting this issue?
Did you ask about Alexa/Google Home because their is a known issue?
Are you prevy to anything being done to address this from Arlo's side?
Thanks,
Justin
arloJo
Would adding a local backup storage drive make it faster?
Model: VMC3030 | Arlo Wire-Free Camera
No, it simply records what's being sent to the server and has no other purpose.
MKPaul
@jguerdat I’m also having the lag issue to my live feed. It’s around 15 seconds. Unboxed yesterday and new firmware downloaded for basestation and each of 3 cameras. App to speaker lag time non existent. Has anyone found a solution to this. Massively disappointed if ‘live’ feed is this slow.
Model: VMC4030P | Arlo Pro 2 Wire-Free Camera
ShayneS
Hi @MKPaul
Have you tried to reboot your base station & test again?
LittleMagic
@ShayneS
A number of us, myself included, have tried rebooting, updating firmware, going thru the set-up process a Nth time, and more. There’s more going on here. The Ring doorbell I setup as a control to see if it was my network setup has negligible lag (1-2secs at most) for the live feed. Yet the Arlo camera right next to it is consistently much slower in displaying a live image.
ShayneS
Hi @LittleMagic
  Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
JP3251
It’s just the product. I also have Reolink and there’s no lag but with Arlo there is.
Model: VMC4030 | Arlo Pro Wire-Free Camera
JP3251
This isn’t true. It’s just the product. I also have Reolink and there’s no lag but with Arlo there is.
Arlo is cloud-based - is Reolink?
JP3251
Yes. The one I have for Reolink I don’t even have local storage
How do you access the camera stream? Via a cloud interface or IP address for the camera (IP camera)?
JP3251
Via cloud
Pkles
It's been 9 entire months yet without a firmware fix for the live video feed delay problem. After checking upload speeds, ping responses, rebooting every camera, Base station, ensuring having good reception signal on each of my devices, and reading lots of complaints about this same problem on many other posts, I would like to know if there is any firmware release scheduled for anytime soon or if I should look for other security solutions on the market. I would much appreciate not being bothered with the same questions that assume the problem is on my side. Thanks.
ShayneS
@Pkles
Does this occur on WIFI & Mobile Data?
Pkles
Yes, in both.
zawaprz
Mine has 16 seconds delay, i.e. I watch live via phone... as a test Rising quickly my arm waiting and putting it down and then counting that event watching live on my phone and see 16 seconds...downed 55mbps/4.5Mbps internet
ShayneS
Hi @zawaprz
Pkles
Customer support will tell you to buy the Arlo Ultra in order to get a delay of 1 to 3 seconds. That's what they told me. What a Shame!! I told them that, that answer would be OK if they were sending me a replacement for free.
Noone was having this delay issue before a firmware update done last year. They just spoiled the product in order for you to buy a new one.
They told me that a delay of 5 seconds should be "normal" for the Pro version. Just imagine having a conversation with a 5 seconds delay! Come on!
I'm experiencing between 8 and 20 seconds delay with a 60/10 Mbps connection and good wireless link strength.
I was considering extending my security system with more Arlo cameras but will absolutely not.
My best advice is to stay away from Arlo
ShayneS
@Pkles
What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
Pkles
@ShayneS
Taking batteries out from cameras to reset them, resyncing with base, checking signal strength, checking Internet speed and ping times, etc.
Please, just have a look at hundreds of messages already posted by many many users on this issue, what they did, based on customer support suggestions and which are the results.
It is really hard for me to think Arlo is not completely aware of the lag problem.
mamarcac
@Pkles wrote:
@ShayneS
Stall tactics. They're counting on people getting tired/exhuasted and giving up and buying Arlo Ultras. They _definitely_ know of the issues, spread over all of the forums here.
ShayneS
Hi @mamarcac
Are you experiencing any live feed lag?
mamarcac
@ShayneS wrote:
Hi @mamarcac
Yes. The live feed is 10-15 seconds lagging. Trying to use the 2-way audio feature is hopeless. But I'm more concerned with the awful pixelated video quality since the May update. That is much more important to fix.
