  • 1 Reply
  • 2722 Views
DDBlackall
How can I increase the volume of the talk-back feature.  It nearly inaudible over any background noise.
It sounds like you're using the app. If the settings for volume are maxed out your only real choice is to use a computer since you can increase mic gain while you can't do that on a mobile device.
