Hi,
I have a problem getting my base station/ cameraes detected on the app(IOS). All lights on base station are green. My WiFi on my mobile is connected to my home WiFi. If I try to connect to Netgear base station wifi it requires a password. Do I need to be connected to this WiFi and if, where do I find this password? I have tried rebooting the base station with no luck. I have also tried connect with android.
You can NOT connect to the base's wifi...that is for the cameras only.
The base connects to you home wifi via ethernet cable so you would connect to the home wifi with your phone to access the base
