Arlo Pro Camera USB Cable Length Limit
Retired_Member
Not applicable
2018-12-28
10:21 PM
I need a long micro USB cable to connect my Arlo Pro camera to a power plug. Does someone know what the longest USB cable can be used before problem occurs? I saw a 9m/30ft USB is offered on ebay specifically for Arlo products. Does it work? Or will the voltage drop too much?
Try it out and let us know 🙂
