  • 1 Reply
  • 1867 Views
Retired_Member
Not applicable
I need a long micro USB cable to connect my Arlo Pro camera to a power plug. Does someone know what the longest USB cable can be used before problem occurs? I saw a 9m/30ft USB is offered on ebay specifically for Arlo products. Does it work? Or will the voltage drop too much?
https://www.ebay.com/itm/Power-Adapter-with-9m-30ft-USB-Cable-Wire-Cord-for-Arlo-Pro-Arlo-Pro-2-Arlo...
Try it out and let us know  🙂
