Arlo Pro Help
  • 1334 Views
Retired_Member
Not applicable
I bought Arlo Pro from someone, I installed the battery and the blue light comes on for 3 seconds then turns off. The sync button does nothing??
Did you also purchase an Arlo Hub?
Retired_Member
Not applicable
I have a hub and another Arlo camera connected to it
ok.
Likely the issue is that the previous owner of the camera neglected to remove it from their account.
Do you have a way to contact the seller?
