Arlo Pro Device appears to offline
Here we go AGAIN ARLO! I just had this same issue on 04.29.21 and wasn't resolved until 05.08.21!!! What is the PROBLEM! I know it's not my internet, not the APP, and it is not that my cameras are too far away from the base! This has been an ONGOING ISSUE INTERMITTENTLY with Arlos cameras! ENOUGH IS ENOUGH! I will be calling the FTC, FCC, and looking for an ATTORNEY for a product that NetGear and Arlo knew was defective!!! Sounds like a deceptive trade problem to me! I have had my cameras for over 4 yrs long enough to know log out, Reboot, etc and I have had enough! SINCE YOU WONT LET ME HASHTAG
What did Arlo remove that you copied? The post looks the same as yesterday.
Thank you for providing your feedback, please reach out to our customer support team so we can investigate this issue further. You will find several options for contacting support in the provided link. Arlo Tech Support
I couldn't leave hashtags when trying to submit my post, so I included them in the actual post which were removed. This is why you don't see them however I copied and saved my original post. I tried hashtags Deceptive, Defective and faulty and they are not in my original post.
My system is monitored by several devices including 2 laptops. My wife's laptop will access cameras but mine won't. Says device is off line, but yet I can access it from all other devices. Deleted from my laptop and re-installed but still comes up with same message. I can review the library but cannot see or control the cameras. Don't see any solutions in the troubleshooting. Any suggestions?
@Retired_Member
Does this issue occur over all web browsers? Can you clear the cache and try again.
Yes to all browsers and clearing cache doesn't help. Is there a limit as to how many devices can access the cameras? I know you can't access from more than on device at a time, but sometimes I access from laptop, or phone, or tablet and sometimes wife laptop. She also has access thru phone and tablet. So all these devices have access to the system.
@Retired_Member
Do you happen to have a screenshot of the error message(s) I can review?
I have a screen shot but don't see a way to post it here.
In the options when replying use the camera Icon but it has to be approved by a mod and can take a while or the Paperclip icon to post a link to it.
ok and how do I get it approved? It's going to ask for a url. Not sure how to go from there. Only thing I can think of would be: https://myarlo.com/#/cameras Is that right?
If you upload the actual screen shot using the camera icon a mod will approve it when they see it, It will just show up as an emblem until then, Since it a weekend it may be a while. A link to it should show right away. You can use the share function in library for a video and select copy url or the url where you saved the screen shot. I believe the share function in the library only last 24 hours though.
Hope I figured it out. ;>)
