DEVICES and SETTINGS are not working on web portal. Tried different browsers.
When using "https://my.arlo.com/#/cameras" (Arlo Web Portal) on-line via computer or laptop, the DEVICES and the SETTINGS are not working in the following Web Browsers (Edge, Internet Explorer, Google Chrome). Only LIBRARY and MODE are working in the above mentioned Web Browsers.
Working fine here on Edge. You can try clearing the Cache if you have not. I did see a post the other day with same problem and they rebooted the computer and it cleared it up.
I cannot see my devices when login using Chrome for PC, windows 10 Pro. Works fine when using Edge, but I prefer Chrome as my default browser. I've cleared my cache. Any tips?
Hi klam55,
Are you seeing this issue when you're using incognito mode on Google Chrome?
