  • 4 Replies
  • 3091 Views
Wesnchris
I have been trying for several months (between my business travels) to contact Arlo to get one of my camera replaced.  I always get an email back telling me they are Arlo software support.  Then they give me a link to use, and it doesn't work.  Can anyone from Arlo contact me to get the camera replaced?
Below is the email I've tried to send numerous times:
To Whom It May Concern:
We purchased the Arlo Pro back on 28 January, 2017. I set up 3 cameras which all worked perfectly. I tried the 4th camera and after installation all it would do is send false alarms (notifications) to my email.
I tried changing batteries, but still received the same false alarms. The false notification was sent because it kept seeing motion where there was none. I even cleaned the lens on the camera. And when I put a different camera in its place, no false alarms. I tried moving the bad camera to another location, and it still continued to send false motion notifications.
The other 3 cameras work great…. How do I go about getting the 4th one replaced?
Wesnchris
Thanks to both of you who provided some guidance.  I had tried the Contact Support---but somehow, someway I kept getting the "Software support" team.  Not sure how kept going to the wrong support team, but I've given it another shot.....we'll see.
Thanks again...
Are you using the Contact Support link at the bottom here?
Wesnchris,
The link the post above is referring to is here: Arlo Support Team
Please let me know if you have any issues opening a case. I would be happy to help.
Wesnchris
Thanks again...
What method would you prefer to use? Maybe we can past a direct link.
