Arlo Pro - Cannot login into myarlo
I cannot login to Myarlo from my iMac using safari 9.1.3. This was working fine for months but for a few weeks now it will not work. I called support a week or so ago and they said they knew about the Mac issue but had no clue when it would be fixed. Also in the last day or two when we use an Iphone it shows arlo as offline. The base station appears to be communicating with the internet. Any fixes or work arounds.
There is a newer version of Safari from July...don't know if that would work for you
OR... can you run another browser like Chrome or FireFox...may work.
