Arlo Pro Base Station middle LED stops blinking. It happens early this week. Otherwise everything is working fine. something new?
As long as it's solid green there's nothing to worry about. The blinking is simply Internet access like your router does. If you're getting recordings and things are working fine, I suspect you're just observing it when there's no access going on.
