I meant to reply sooner but the most bizarre coincidence fixed this issue.
We had an electrician come to fix something and he had to switch off the main power in the breaker box. Since then, Arlo has been working without any of the previous issues.
I guess it reset everything at the same time, including the modem and the base station.
Something worth trying.....
When "offline", what are the base LEDs showing? If all 3 are green, I'd submit that it's not offline. I occasionally get this and force close the app and log back in. Almost always, this cures the problem. Also, try using a browser to see if that works.
If this works, we have no real way of debugging it. It may be the app, it may be the devices, it may be the connection, etc.
The middle light (internet connection) is completely off - not even amber.
The other two remain green.
That means the base isn't even connecting to the router. Try rebooting the router and base, in that order, letting the router initialize before starting the base.
Thank you for your responses.
I have tried your advice (rebooting the router then the base) for the last two days but the base station still disconnects from the internet about twice a day, and the only way to get it back online is for me to manually restart the router.
Im not too sure what more to do. Is it possible that something is wrong with the base station?
Not sure if this was ever resolved, but one cause of a device losing a connection from the router is an IP device conflict. In homes with dozens of devices connecting to the same router it's not an uncommon problem. You can check to see if this might be the issue by logging into your router when the device is working and checking the IP address. Then when it's not working, do that again and see if another device is using that IP address.
The easiest solution is to set a fixed IP address to the ARLO hub, then it can't be arbitrarily assigned to another device.
I think the issue is either caused by a recent firmware upgrade or Arlo is having issues on their end. I'm experiencing the EXACT same issue.
