Arlo Pro Base Station Setup Help
Can't connect because when I open my Android Phone settings The Netgear base station is asking for a password.
What is this password?!?!?!?
You're not following the directions for setting the system up. You'll never be able to log into the base directly. Follow the directions to claim the base and then sync the cameras.
