  • 2 Replies
  • 2946 Views
Psv2363
I have had these 3 cameras for a little over 2 weeks now and the 3rd camera only stays on line for about 1hr and then goes off lineand drains the battery. I have done everything I can possible think of to correct the problem. I have switched batteries. I have moved the camera. I have uninstalled the camera and reinstalled it and i have resynced the camera. this camera is only about 25 feet from the base in which the other 2 are farther away and work fine.
Sounds like a bad camera ...  About the only thing you haven't tried is to run it from the power adapter / cable without the battery pack installed...
( don't think it will make a diff in this case )
Contact Netgear Support for possible warranty ( or swap at store if possible )
Psv2363
Thanks TomMac. Thats what I am starting to think. I have been in contact with NetGear since the begining and have done everything that they have suggested but I have had no success. I wish I could just replace it at this point.
