Arlo Pro 2 way audio
Does an Arlo Pro camera that's being used with the original Arlo base station do 2 way audio, or do you have to have the Arlo Pro base station for 2 way audio?
No need for the Pro base.
All on the PRO camera functions 100% on the regular base.
What you loose is the local record and the siren as they are physically located on the pro base.
